Up to 20% off select tools
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Broken wire - hyper x cloud 2
Hello, the tip of my wire at the jack is broken. Is there anyway that I can fix it, or is there anywhere I can get it repaired? Thanks.
Score 3
1 Comment:
can you post up a picture? thats a pretty cague description of what is wrong lol
by Share
Add a comment
1 Answer
My headset had the same issue. I ended up replacing the connector. If you snip off the connector and solder a new one on that should solve the issue. Just make sure you solder the wires to the same spot they were before. Here is a good guide: https://www.youtube.com/watch?time_conti...
Add a comment
Add your answer
Kidus Biya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 4,361
