Sound is not working
I only have sound when using headphones. How do I get my speaker to work?
Tried various fixes I found online for the same problem with my LG Stylo2. This is what worked for me....Remove the back cover of your phone and push on the speaker (left bottom) a few times. All of a sudden I have sound again. Loose wire likely cause inside speaker!! Hope this works for you.
Thank you!!... I tried all sorts of things to get my speaker working again!... I almost did a factory reset on it.. Who would've thought something so simple would work! Lol.... Thank you again for your advice!
Thank you! This worked.
I am so glad. Did not know if this would last but 4 months later and mine is still working with no problems. Glad I could help.
It worked for me too!!!
and anotha one!!!!
You got to take the back off and screws out take off souronding plastic molding there is 2 pins connected on the speakers itself they must be touching the tape or ribbon perfectly or you will not get sound go to YouTube for video on how to take phone apart properly
Had the same issue took it all apart & put it back nothing, sprayed the contact cleaner ,pulled the speaker out tested it outside it was good, then i saw where the speaker sits if you push the cover you'll hear a click that is the notch that pushes the cover & makes the contact.
thanks so much i try this way my problem was resorve .
The push and click worrrrrked! Thank you so much!
Pushing of speaker repeatedly from left to right or from right to left by removing just back cover
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 13,194
3 Comments
I have to same problem it say my headphones are in but they are not
by Jasmine Benedetto Share
It shows headset logo on screen and sound is not working
by ojewezt198 Share
I am having the same problem with my LG Q Stylo+. If anyine has anyrhing to help please contact me at aedanouellette@gmail.com
by Aedan Ouellette Share
