1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
System freezes and also get folder with question mark
I actually have an A1466 model of air. A few months ago if started freezing either on startup or while your using applications, very random. I am forced to press power button to shut down and restart. On startup it will come up with symbol of folder with question mark. I have ran some test and it showed a code which talked about memory problem. Finally got a new logic board and swapped it out on the advice of an IT friend. After putting everything back to together and started up it froze again. Forced a power off and restart. On restart I received folder with question mark. My question is what next the SSD or another logic board. Suggestions please.
2 Comments
Did you ever figure this out? I have the same model and the same problem. The computer will be acting normally and suddenly freeze. Upon restart I get blinking folder. After another restart generally it loads normally. Not sure what is going on but it seems random, meaning I can’t discern what is triggering it. It’s happened twice and both times I was in my browser.
by
@danj is this possibly the same issue with the APSF?
by
Add a comment
Chosen Solution
@mikemcglaven Mikem, try rebooting pressing option key and choose recovery partition to start the system. When you get to the options screen open disk utility and run a diagnostic to check the Ssd works properly. Might be some error with that.
Score 1
Add a comment
That symbol means no bootable or storage found.
Add a comment
Add your answer
Tom Hall will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 952
