Up to 20% off select tools
Karbonn released this phone in September 2014 as part of the Android One initiative. The Karbonn Sparkle V (also called the Karbonn Android One Sparkle V Blue) was released in September 2014.
partially not working touch screen
my phone model is karbonn a81 star, i had replaced touch screen after that the top most part of the screen is not working what is the solution for this pls help me
Score 1
Add a comment
Most Helpful Answer
tvmitc could be either a bad digitizer (most likely) which would need to be replaced once more or a loose connection. Double check your work and make sure that everything is properly connected. If so, contact the vendor your bought the touchscreen from and ask for a different one. Badd parts and poor QA are not an uncommon issues.
Score 1
1 Comment:
when i fixed firstly the home buttom was automatically working at that time the top most portion and the notification bar was working fine ,later i replaced and again when i check the topmost portion was not working and the automatically working problem was solved
by Share
Add a comment
Touch screen are not working
Add a comment
Speaker not working why options
Add a comment
Add your answer
tvmitc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 38
All Time: 815
