Up to 20% off select tools
The fifth-generation Volkswagen Jetta was introduced in January 2005.
Why does my engine cut out while driving?
I do have a transmission issue (3rd gear incorrect ratio)
But while I drive my engine cuts off stopped at a stop light without warning and can turn it back on without any issues.
When it shuts down a battery symbol is shown but once it turns back on it goes away.
Can my transmission be the cause of this or would it be something else?
Add a comment
1 Answer
Most Helpful Answer
Really need to scan the car for the best answer. However, if it cuts out and shows a battery symbol the best place to start would be the charging system. Need to look at both your battery and alternator to see if A. your alternator is putting out enough charge to keep your battery topped up, should be around 14V. Also if your battery is still in a good enough condition to accept a charge.
A scan though, would be your best bet, as VAG cars can be somewhat temperamental.
Score 1
Add a comment
Add your answer
Jose will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 1,273
