Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Is this a battery leak?
I opened an iPad Mini earlier to replace the screen and found a shiny coating on one end of the battery. Does this look like a battery leak?
The coating is already dry and feels fairly smooth. It only appears along the top of the battery along the edge that's exposed under the LCD shield plate. There's no sign of fluid below the battery or elsewhere in the iPad. This device has been repaired before.
If it's not from the battery, is there anything else in there that might leak? The LCD looks fine. There were no reported battery issues, either.
Add a comment
That does not look right.. Looks like something melted at the bottom of the battery.
Add a comment
Yes, you will probably have to replace the battery and any components that have been damaged by the leakage.
It looks at though the battery acid has dried up.
Add a comment
Add your answer
Ket will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 21
All Time: 1,450
