Up to 20% off select tools
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Remove Bench Back Seat
How do I remove the bench backseat?
Score 1
Add a comment
Chosen Solution
Force the lower end of the bench seat back toward the trunk to release to clips at the bottom of seat and lift out--You will find either clips or screws at the lower end of the upper portion of seat--release these and lift upper section of seat should release from locking clips allowing removal of upper section
Score 7
7 Comments:
am amazed by the things you know! ;-)
by Share
ah shucks ma'am
by Share
How do you get the clips to reatatch thanks
by Share
Does anyone know what these locking clips are called? They are broken and I cannot put a car seat in my car because of it. I need to order new ones ASAP
by Share
i cannot seem to locate any hardware on mine. looks like its a pin on both sides, and this runs straight into the seat. I've removed the lower seat, cannot get the fold down part out.
by Share
Show 2 more comments
Add a comment
if your release strap on your upper backseat is broke, stick a pair of needle nose pliers in the opening right in the middle of the upper backseat grab the latch and pull. now just go do it.....
Add a comment
I took the seat out and broke the clips because I didnt read anything first. Like a idiot. What is the best way to replace the clips? Or just buy a new backseat?
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 36
All Time: 22,808
