Repair guides and support for a wide range of Vespa scooters.
Vespa steering column lock removal.
Hi I have removed the steering column on my Vespa LMR Star . But I can't get the steering lock out as I need to replace as the keys are lost. Do I knock it out or is there another way to remove it . I would appreciate any advice you can give me thanks Gerry.
1 Comment
Gerald Murphy LMR or LML Star? If it is LML Star then it will help if you give us the model number as well.
by
Add a comment
1 Answer
Most Helpful Answer
Gerald Murphy it should be riveted in. Post some images of your lock etc. with your question so we can see what you see. Use this guide Adding images to an existing question for that. See if this video looks like your lock
Score 1
1 Comment:
Thank's for your help much appreciated.Should have the bike on the road in time for the spring .Gerry.
by
Add a comment
Add your answer
Gerald Murphy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 882
