Fujifilm Finepix S4200 is a 14.0 megapixel bridge digital camera released by Fujifilm in 2012.
On off button sticking and stiff
My on off button seems hard to move and sticks in postioymoved to it used to just spring back by itself
Score 1
1 Comment
Tried it made slight difference button still not working properly one of the kids must of dropped it as it still doesn’t move back itself as it use too but thanks for your suggestion will probably have to take it to a repair shops
by
Add a comment
Chosen Solution
Sounds like a button that is physically stuck, like you said, get a bottle of Isopropyl Alcohol and a Q-Tip, dip the Q-Tip in the bottle, gently swap the switch with the wet end of the Q-Tip (make sure the device is off) switch back an forth. Rinse and repeat until the switch is loose again. Hope that helped!
Score 1
1 Comment:
Where can I purchase a new button. My button came completely off?
by
Add a comment
constant problem with these cameras. even lubrication does not help
1 Comment:
I put new batteries in the camera and won't come on
by
Add a comment
Add your answer
gazza b will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 54
All Time: 3,334
