The XV50 Camry was introduced on 23 August 2011, and began U.S. sales in September 2011. The interior received a major restyling, while the exterior received all-new sheet metal and more angular styling.
Why is the Bluetooth cutting out?
The Bluetooth has worked very well for the past year, - until just yesterday. All of a sudden, it stopped, during the middle of a phone call. And even though it said it was connected on the phone's screen, the Camry's screen said it was off and would not connect or even allow anything to be changed. After stopping the vehicle and turning the entire car off and back on, the Bluetooth worked again. But then later, it stopped again. Why is it cutting out?
Score 2
Add a comment
1 Answer
Most Helpful Answer
1. Remove your phone from car Bluetooth
2. Remove your car Bluetooth system from your phone.
3. Wipe out cach files from your phone. You can find instruction for your type of phone on internet.
4. Reinstall software for your car system( for Toyota reinstall entune software )
5. then go through setup process and connect your phone to your car
Score 1
2 Comments:
Does this only work for newer vehicles? I have a 2014 Toyota Corolla, I don't think it has that same entune software. But I do have similar issue. I will be driving along and the music part of my phone according to the car display is disconnected. And the only way to reconnect it is to be stopped (stupid safety feature) and select reconnect from the car display. Sometimes if I catch the disconnect fast enoughand press pause on the car displayand wait for a fast forward sound I can press play and it will work again. But this doesn't always work. I had this problem both with an iPhone and Samsung galaxy s21.
by
My Aygo 2014 Bluetooth keeps cutting out playing music and my sat nav. Works fine on phone calls. Have tried removing phone pairing and updating phone software but it’s still doing the same thing. Any ideas?
by
Add a comment
Add your answer
Carl Miller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 13,234
