Samsung's flagship phone, the Galaxy S8. Released in April 2017.
Broken screen. Can not use touchscreen
I dropped my S8. The part where screen is broken still works. But, the rest of the screen, does not work. Therefore, I can't even turn phone off. And, I can't transfer pictures without touching the allow button. It won't let me. Any suggestions?
Score 4
Add a comment
Most Helpful Answer
It's probably a little late, but I used Google voice to do things for me when my phone stopped letting me touch the screen. It allowed me to do many things, if you know the lingo it helps a lot. I just said "ok google (...)" with what I needed to get done on my phone before getting a replacement.
Score 1
Add a comment
I was able to connect a logitech M557 Bluetooth mouse
Score 1
1 Comment:
How did you do that? I want to use it as a dex with a qi charger.
by
Add a comment
Laura Rogers the only way to fix this is by replacing the display assembly. Use this guide Samsung Galaxy S8 Screen Replacement for that
Add a comment
You can definitely replace the Glass and LCD with just the glass and LCD, but for ease of repair, may I suggest buying the glass and LCD with the midframe attached. It has a much better end result in how the repair appears cosmetically.
If you're not feeling that risky, look for your local Ubreakifix. Ubreakifix has a partnership with Samsung with OEM quality parts and prices lower than the part is usually listed online.
1 Comment:
I had this put 7Juuu
by
Add a comment
Try changing the battery.
Add a comment
Add your answer
Laura Rogers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 23,196
