Up to 20% off select tools
Repair information for the Canon PIXMA iP4700 color inkjet photo printer. Released in 2010. Model number: iP4700.
My printer is having problems Printing.
My ip4700 is printing very faint lines or not at all. This is mostly the black print but the colors are having similar issues.
I did a nozzle check and it was perfect. Everything printed fine. The instructions say not to do a cleaning if the nozzle check is okay.
Any ideas? Thanks.
1 Comment:
Hi @dreemsnake ,
What happens if you copy or scan a document using the printer's control panel, does it print OK?
If it does and you are only having problems when printing from a computer, what OS is installed in the computer and how is it connected to the printer, wireless or cable?
by Share
Add a comment
1 Answer
I would suggest running a cleaning a couple times, and if that doesn't resolve the issue, try replacing the ink cartridges.
Add a comment
Add your answer
lori will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 837
