The second generation of Citroen's supermini car was produced between 2009 and 2016.
Why is my gearbox faulting?
I have a strange, intermittent issue, where my car (auto) fails to shift gears within the first 5 minutes of driving, but only during specific conditions. When it fails, there is a lurch forward, and a Gearbox fault digital warning appears. The SERVICE lamp also turns on. All I have to do though is pull over, and restart the engine. None of the warnings come back on, and the car doesn't experience a fault after that.
The problem: My car's gearbox faults
The conditions:
  • Cold, or just warmed up engine.
  • Going up hill
A mechanic has suggested I need a new gearbox - but I'm not sure it's specific to the gearbox itself. Before I spend a bunch of money on a new gearbox, does anyone have any ideas about what this is or how to fix it?
Score 1
2 Comments:
For anyone with the same problem. Sounds like it could be this: https://www.citroenc3owners.com/c3-autom...
by
Hi did you find the problem I have this exact same issue?
by
Add a comment
1 Answer
I needed to change the item below "clutch Actuator" The price is in Dansh Kroner - that solved the problem
LL90118 Slavecylinder, kobling Actuator 1 Stk. 3.399,00 3.399,00
Good luck and happy new year :)
Jan
Add a comment
Add your answer
Hannah G will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 60
All Time: 3,992
