The fifth-generation Elantra debuted at the 2010 Busan International Motor Show in April 2010. The fifth-generation Elantra (2010-2015) added a two-door coupe variant in addition to the standard four-door sedan model. These Elantra vehicles included six-speed automatic or manual transmissions.
Camshaft Sensor Location Please
I have a 2013 Hyundai Elantra GLS and I cannot find the Camshaft Positioning Sensor. I have error codes and constant stalling. I have already replaced the Crankshaft Positioning Sensor which is down low to the right of the oil filter as you are facing the vehicle. I need to find the Camshaft Sensor. Every diagram just points to the upper left quadrant of the vehicle close to the oil cap. Can someone assist me please? I have the sensor just need to know where to stick it.
Add a comment
Most Helpful Answer
@woodywool there should be two. One for the intake and one for the exhaust. Post some picture of your engine with the engine cover off.
Score 1
Add a comment
it is close to the fly wheel
1 Comment:
Are you thinking of the crankshaft position sensor? Because as @oldturkey03 stated, there are two camshaft position sensors; one for the intake and one for the exhaust, and they're located on the top of the engine, right hand side as you're facing the engine.
by
Add a comment
Add your answer
Lenoy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 59
All Time: 1,666
