Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Dissabling the microphone on the OP3
Hello,
I read this story on wired How to Rip the Mics Out of Your MacBook and iPhone . Would it be similar for the OP3?
This is because I could find any obvious cables on the dismantling tutorial.
Cheers!
Score 1
1 Comment
How Can I'll be Correct Microphone
by
Add a comment
1 Answer
Chosen Solution
Hi @radconnorcon ,
According to this link the microphone is on the charge port flex cable.
Here is a link to the ifixit Oneplus 3 Teardown guide. At 4:11+ minutes into the video the microphone is accessible.
You could always try gently (stress gently) permanently removing the microphone from the cable and then re-assembling the phone. (I doubt that the microphone would be able to be reinstalled successfully - you'd most probably have to install a new charge port + microphone flex cable)
Hopefully the phone should still work if you use the earphones with the microphone attachment if you feel the need to make or receive calls.
Alternatively you could just simply block the phone's voice inlet hole on the bottom of the phone with glue or perhaps as a temporary test measure, clear adhesive (sticky?) tape to prevent sound reaching the microphone. This should achieve the same result with less potential damage from having to open the phone etc, occurring
Glad I'm too old and hopefully considered not interesting enough for it to be worthwhile to be bugged by anyone. Life's simpler this way. Cheers ;-).
Score 3
Add a comment
Add your answer
Conrad Connor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 39
All Time: 1,070
