Released August 2013. Identified by model number Z796C
How can I fix stuck on white screen
Stuck on white screen
Score 4
6 Comments:
You will need to supply more details. like, Did you attempt to fix anything on it recently? did you drop it? did it get liquid damage?
by
Dropped it and waited on it to die. Still on white screen
by
Hi @hogan77 ,
try removing and then replacing the battery and check if this resets the phone
by
I have the same problem but I didn't drop it the ZTE powered by Android screen comes on fine but then go straight to all white idk what to do please help
by
My ZTE Majesty is also doing this, after a day and a half of a white screen it just decided to work for me... I've had this phone for 17 days and the return policy only allows 15 days to return electronics... Figures.
by
Show 1 more comment
Add a comment
1 Answer
A white screen could be caused by a loose led connection. You need to take it apart and check screen commection.
Add a comment
Add your answer
Brandon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 3,335
