Up to 20% off select tools
Repair guides, user manuals, and technical specification for the Acer Aspire 5552. The Acer Aspire 5552 is a budget laptop equipped with a 15.6 inch screen, 250GB of storage, and a DVD writer. A laptop with modest performance for a cheap price.
Power On No display
Its Power on but gives display sometimes and sometimes not give display
1 Comment
maybe a loose cable
by Share
Add a comment
Chosen Solution
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
Score 3
Add a comment
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Add a comment
Add your answer
Tech Team will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,069
