Repair guides and support for the ZTE n817, also known as the ZTE Quest.
Why is my mobile network state disconnected
My zte legacy n817 keeps showing disconnected on the mobile network state and it's through qlink wireless it's not letting me make or receive calls or texts its not roaming I have minutes and unlimited text even 1gb data my plan was just refilled and it never has done this before it started two weeks ago out of nowhere and I done went to roaming settings and ping test menu tried changing network's it won't work on any how do I fix this
1 Comment:
I am having the same problem and I have zte l2 blade
and noboday is helping me if thy helped you please help me
by
Add a comment
1 Answer
The “Mobile Network State Disconnected” is associated with a poor cellular network or wireless signal reception on the mobile. The problems occur generally either due to a faulty antenna or a corrupt SIM card.
You might have encountered the “Mobile Network State Disconnected” error on your mobile when the mobile is on poor network reception or you are trying to connect to a wifi network as well. Every time you attempt to access the internet a pop-up shows up “Mobile Network State Disconnected” with a close or ok button.
here is the solution: Straightalk phone keeps saying Mobile network state disconnected
Add a comment
Add your answer
taniaha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 2,094
