The second generation model's body has a wider track and longer wheelbase than the previous MDX. The engine was upgraded to a 3.7 liter V6 tuned for 300 hp. It accelerates from 0-60 mph in 6.5 seconds, one of the most powerful engines Honda has produced to date.
Battery is not charging
my car is able to drive. I have no power steering and the wheels are difficult to turn. The indicator light say the battery is not charging. What is causing this
1 Comment
Have you checked the alternator?
by
Add a comment
1 Answer
Most Helpful Answer
@expofrosty double check your belts. Since you have no power steering and your "Battery not charging" could be a sign of a broken alternator belt. If the belt is okay you will have to consider to get your alternator checked (try places like Autozone or your dealer) with a worst case scenario of replacing your alternator. Check on here for that.
Score 2
Add a comment
Add your answer
Bob FitzPatrick will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 24
All Time: 1,175
