The EOS 6D was released in 2012 as Canon’s first consumer-level, full-frame DSLR. It comes pre-equipped with a 2.75”x2” LCD viewing screen, a GPS antenna and wifi connectivity.
What connector is this?
Does anyone know what the 10 pin connector is that sits behind the rear rubber piece on the right side of this camera? I'm assuming it's some sort of service port but curious to know if there's any ability to interface to it. Looks like most Canon DSLRs have some variation of this connector (number of pins varies)
2 Comments:
I see the SD card slot. It has 10 pins and is on the right. Not quite sure where I'm looking at.
by
sorry i should have been more specific. On the back of the camera there is a rubber grip that goes from the top of the camera, around the rear dial. If you pull that piece up, it exposes this connector.
by
Add a comment
1 Answer
Here is the manual.
http://gdlp01.c-wss.com/gds/9/0300004019...
Are you referring to HDMI mini or the charge/data port?
Add a comment
Add your answer
Dan DiGregorio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 30
All Time: 494
