Up to 20% off select tools
The HTC Desire 610 is a touchscreen smartphone that runs Android software. It was released in February 2014.
hard reset is needed
There was low battery yesterday and it shut down. I put it to charge and in the morning when I tried to turn it on it started to turn on and off. I tried to reboot, tried to do recovery and tried to do factory setup from hboot recovery menu but its still restarting. what can I do ? can I do something without using PC ? thank you beforehand
1 Comment:
Its possible that you might have to some how find and flash the stock firmware. I am not sure as i have not messed with many HTC phones not have i seen one fail after a battery drainage.
by Share
Add a comment
1 Answer
The "turning on and off" doesn't sound like you need a factory reset.
Try
a) a different or higher Amp charger. Normally they are 5v/1A, try a 5v/2A.
b) have someone look at the battery.
Add a comment
Add your answer
Sarvar Saidov will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 307
