Up to 20% off select tools
A Nokia E-series smartphone with a physical QWERTY keyboard and Optical Navi Key. Successor to the E71. Released in 2009.
Question regarding possible Camera replacement/upgrade
Will a Nokia E72 replacement camera part work in the Nokia E71 motherboard? In other words, can one upgrade the Nokia E71’s 3.2 MP camera to 5.0 MP using a spare part made for an E72?
Since the phones are very much alike (same size, same battery, etc.) I should think a simple swap should be possible, as long as the physical size and connector of the replacement part matches the original.
Thanks for your help.
Add a comment
1 Answer
Chosen Solution
Simply put, no. Not in hardware nor in firmware is it compatible.
Score 1
1 Comment:
Thank you for your response. I was hoping it could be a simple swap of cameras.
by Share
Add a comment
Add your answer
Gam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 422
