Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
How to change headlights bulb
How to change headlight bulb
Add a comment
Chosen Solution
This should help
https://www.youtube.com/watch?v=8tglvV6S...
Score 3
Add a comment
@bexon59 open the front portion of the wheel liner. You should see a white cap with ridges and a tab, open that. Next there should be a silver connector socket with a lighting bolt symbol, pull that off. You should now see the back of the bulb and its clip. Squeeze the clip and pull it back to remove the bulb. This video also not the best, should help you with that.
Score 1
Add a comment
IF you open the hood of your car there should be a big black screw (somtimes plastic) if you unscrew that you can pull you head light out and disconect the wires. Then you can take off the back cover to the headlight and change the bulb.
4 Comments:
its that way in my car
by
@tylor_b you have a Nissan Murano?
by
Hes got an old ford escort or some $@$*. My murano is alot more complicated.
by
Add a comment
You can get to it from the inner fender, removing the front wheel well weather protector.
Add a comment
Add your answer
Verland Laurent will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 17,620
