Repair guides and support for the Huawei P9 Lite, released in April 2016.
Booting loop help Huawei p9 LITE ALE-L21
My Huawei p9 LITE model ALE-L21 is stuck on booting loop. The baterry is on about 1%, and when it starts, it shows it's laoding, then it shows Huawei logo and booting, then black and huawei logo, and it repeates. I really need some help!
Add a comment
1 Answer
Chosen Solution
Hello
Give this a try.
The best thing that you can do right now is to check if the problem is caused by a system glitch. You will need to perform a factory reset on the phone from the recovery mode. Take note that this action will erase your phone data.
*Hold down the Power key to switch off the device.
*Press and hold Volume Up and Power key.
*Release the keys as soon as the Huawei logo appears on the screen.
*You should be in a Recovery Mode menu.
*Navigate here by using Volume buttons and select options by using the Power key.
In case the problem still occurs after the reset then this could already be a hardware related problem in which case you will need to bring the phone to a service center and have it checked
Score 1
Add a comment
Add your answer
JEREDEK will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 32
All Time: 5,198
