Repair guides for Gear Fit2, Samsung's fitness-oriented smartwatch, released June 2016.
Gear Fit 2 no turning on...again
My gear fit 2 will not turn on. It does not show as charging either. I put it on the charger last night with 20% charge remaining and this morning it will not turn on or show as charging. I had the same problem a month ago and it was sent to Samsung repair centre in Toronto. It was returned working and fixed under warranty. Now I am in Florida and it does not work less than a week later. What should I do?
Add a comment
Hold Down the power button while placing it on the charger. Hold for 30 seconds and let go. charging light should stay on..
-Warner
Add a comment
I tried it, then the screen appeared all white. I hit the button again and the lightning bolt comes out at 1% then it goes back to a full white screen.
Add a comment
In my watch charging symbol is showing and turning off
Add a comment
Add your answer
Don Newton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 2,411
