Eighth generation of the Mazda Protege.
Alternator not charging battery
Which fuse is for the alternator?
Score 2
3 Comments
Canbie bateria y. Cambie el altrnador y cuando lo camino un largo rato con luces se apaga yle paso corriente y prende lo tengo que mantener aselerado nose apaga pierde luces y poder al caminarlo si lo tengo prendido nada mas nose apaga
by
Jaime Gomez, will this video will help you?
https://www.youtube.com/watch?v=--AdY8z1...
by
Canbie battery and. Change the altrrador and when I walk a long time with lights it goes out and I pass it by and turn it on I have to keep it safe and it doesn't turn off it loses lights and I can walk when I walk it if I have it on just after it goes out
@Jaime Gomez there is a lot that gets lost in translation. Any chance you can explain the problem a bit better.?
Jaime Gómez hay mucho que se pierde en la traducción. ¿Hay alguna posibilidad de que pueda explicar el problema un poco mejor?
by
Add a comment
Most Helpful Answer
Hi Ray, put a voltmeter onto the battery while the car is running to make sure that the alternator is putting out enough current.
Score 2
2 Comments:
i have done that and still no change
by
@raysmazda if you aren't getting a reading on the voltmeter while the car is running then there is a good chance that the alternator is bad.
by
Add a comment
@raysmazda like @blakeklein elude to, you do want to check that when the car is running, that there is any change in the battery voltage. If not and all the wiring is good,it is most likely that there is an issue with the PCM. The PCM functions as a voltage regulator. To answer your direct question, there is no fuse for the alternator.
Score 2
Add a comment
It's most likely going to be a dead alternator, does your dashboard like up like a Christmas tree?
Score 1
Add a comment
Add your answer
Ray Hunt will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 32
All Time: 4,841
