The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
My motor stage broken?
it is saying that my motor stage is broken.....can you help
Score 2
2 Comments
Same problem, though i suspect its the brushes in the motor( a piece that uses electricity to spin the motor and magnets). And my wire on the leg of the drone broke.
by
I have same problem but when I turn it on the perpellar acts like it wants to spin a sec then red-light comes on
by
Add a comment
Most Helpful Answer
Not connected to one or all motors. Broken cable, connection not seated correctly, (Push Fit) and connection under arms damaged.
Score 4
Add a comment
I have this issue.
Do I really have to go through the process of taking everything apart in order to fix this?
Score 1
1 Comment:
Is this un fix able? also the other thing is it wont turn off with the press of the button, I have to unplug battery to turn it off.
by
Add a comment
As @https://www.ifixit.com/User/3081968/Mich... pointed out this is one or more motor connection issues.
As per https://www.ifixit.com/User/3695100/swiv... from flight app view, we can find which motor is not connected as it’s red.
For me even though how hard I pushed the connector it did not work properly. The connector was loose. (even though I connected a different motor it did not detect by the motherboard.) I used my multimeter ohms scale which has around 1 Ohm per each of 3 pins. I removed the motor connector and sold it directly to the motherboard :). Did the trick for me and saved some money and time as well.
1 Comment:
The motor turn just a little when I first turn on though but then goes to motor stage error
by
Add a comment
I had the same problem motor stage broken. I unistalled the free flight pro app. Then I reinstalled it and it fixed the motor stage broken. Hope you get the same results
Add a comment
Add your answer
Ciara Refosco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 5,171
