Repair guides, disassembly, and troubleshooting information for the third-generation Apple iPad with 4G, available with 16, 32, or 64 GB of storage. Released in March 2012. Identified by model numbers A1430 (GSM, AT&T) or A1403 (CDMA, Verizon). Repairs require the use of heat and careful prying.
Ipad stuck on a restart loop
Hey guys,
Yesterday my Ipad 3 got stuck on a restart loop. Earlier the machine worked fine, but now every 2-3 minutes it restarts. I tried to restore factory defauls and did hard resets and all, but now I can't even get past the ipad activation window, because the machine will restart it self.
I tried to get some sort of log with itools and all here's the last lines i can find in the log before the machine restarts itself. Any idea what could be causing this?
Oct 12 22:01:55 iPad syslog_relay[148] <Notice>: syslog_relay found the ASL prompt. Starting...
Oct 12 22:01:56 iPad assistantd[52] <Warning>: [Warning] Services all disappeared, removing all accounts
Oct 12 22:01:56 iPad assistantd[52] <Warning>: [Warning] Bad response (null) from daemon for setup info
Oct 12 22:01:56 iPad assistantd[52] <Warning>: [Warning] Services all disappeared, removing all enabled accounts
Oct 12 22:01:56 iPad assistantd[52] <Warning>: [Warning] Services all disappeared, removing all dependent devices
Oct 12 22:01:57 iPad mobileactivationd[95] <Notice>: 0x40197000 MA: -[MobileActivationDaemon createActivationInfoWithCompletionBlock:]: Activation info creation requested by lockdownd<31>
Oct 12 22:01:57 iPad mobileactivationd[95] <Error>: libMobileGestalt MGBasebandSupport.c:60: _CTServerConnectionCopyMobileEquipmentInfo: CommCenter error: 1:35 (Resource temporarily unavailable)
Oct 12 22:01:57 iPad mobileactivationd[95] <Error>: libMobileGestalt MGBasebandSupport.c:189: No CT mobile equipment info dictionary while fetching kCTMobileEquipmentInfoIMEI
Oct 12 22:01:57 iPad mobileactivationd[95] <Error>: libMobileGestalt MGBasebandSupport.c:189: No CT mobile equipment info dictionary while fetching kCTMobileEquipmentInfoMEID
Oct 12 22:01:58 iPad notification_proxy[139] <Error>: 0x40115000 -[MNPLockdownConnection receiveMessage]: lockdown_receive_message error!
Oct 12 22:01:58 iPad notification_proxy[139] <Error>: 0x40197000 -[MNPLockdownConnection receiveMessage]: lockdown_receive_message error!
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 0: (-2147483648, -2147483648)
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: Could not get value for 0
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 6: (-2147483648, -2147483648)
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: Could not get value for 6
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 2: (-2147483648, -2147483648)
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: Could not get value for 2
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 1: (-2147483648, -2147483648)
Oct 12 22:01:59 iPad CLTM[23] <Error>: CLTM: Could not get value for 1
Oct 12 22:02:00 iPad ReportCrash[152] <Warning>: Report of type '288(288)' not saved because the limit of 100 logs has been reached
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 0: (-2147483648, -2147483648)
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: Could not get value for 0
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 6: (-2147483648, -2147483648)
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: Could not get value for 6
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 2: (-2147483648, -2147483648)
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: Could not get value for 2
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 1: (-2147483648, -2147483648)
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: Could not get value for 1
Oct 12 22:02:04 iPad CLTM[23] <Error>: CLTM: partial sensors: count 16, current c3ff, mask 441, expected 441
Oct 12 22:02:09 iPad powerd[62] <Error>: Unexpected readFromIdx -1. arrCnt=227
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 0: (-2147483648, -2147483648)
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: Could not get value for 0
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 6: (-2147483648, -2147483648)
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: Could not get value for 6
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 2: (-2147483648, -2147483648)
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: Could not get value for 2
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: bad BB temp sensor 1: (-2147483648, -2147483648)
Oct 12 22:02:09 iPad CLTM[23] <Error>: CLTM: Could not get value for 1
Score 1
Add a comment
1 Answer
Chosen Solution
Did anything happen to your iPad shortly before this issue appeared, such as drops, impacts, water or repair attempts?
The log shows lot's of BaseBand issues, specifically, temperature issues. These are logic board issue and I suspect that only a trip to a micro-soldering repair shop will be able to get to the root of this.
Score 1
Add a comment
Add your answer
Juha Nyman will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 14
All Time: 927
