Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
Can individual keys be replaced?
I have a few sticky keys on my 2017 MacBook. I think I have spilt something, I tried using compressed air and cleaned them with solution, but it hasn't worked. Is it possible to replace individual keys?
Score 4
1 Comment
I have a damaged E key and the cap came off. However when I depress the key it won't register. Would anyone know if a replacement key (including the key and hinge) should fix this issue. I was wondering if a single key replacement would work in this regard or I would need a complete keyboard replacement.
by
Add a comment
Most Helpful Answer
You can buy individual keys online, yes... just google it. People mark it up because they know about folks like you that need single units. They're easy to put back on.
When I messed up a few of mine, Apple just replaced the whole top case, saying they don't do single key replacements.
Score 2
Add a comment
assuming you mean the keycaps then yes it is, look at step 7 here and you will find that they are held down by 4 small clips Retina MacBook 2017 Teardown
otherwise possibly but it might not be worth trying with the 1/10 repair score.
Score 1
Add a comment
Add your answer
Tara May will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,732
