Up to 20% off select tools
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
iPhone 8+ and iPhone 7+ lcd
iPhone 8+ display compatibility and iPhone 7+?in Ches the difference
Score 3
Add a comment
Most Helpful Answer
Here's the latest info on the iPhone 8:
iPhone 8 Teardown
Score 3
Add a comment
Both of them can't work well on each other. I write an article "What’s the difference between iPhone 8 and iPhone 7 LCD screen?", if you want to see it please see my profile then visit my blog. Also you can watch the video here:https://youtu.be/KxFovnbcY3E
Score 1
Add a comment
Be VERY AWARE of chinese sellers on eBay trying to pass off iPhone 7 Plus screens for iPhone 8 Plus. They nearly look identical.
Score 1
1 Comment:
7 has hooks at the top and 8 has metal brackets
by Share
Add a comment
They looks similar but they can't work well on each other or say it not full functioning on each other,
Score 1
Add a comment
No, you wouldn't be able to interchange displays between generations of iPhones. The 8 uses a 3 channel, temperature sensitive light sensor.
The 7 uses a single channel, light only sensitive sensor.
The ribbon cables are also likely different.
Add a comment
Yes you can put the iPhone 8 + digitizer on a 7+ iPhone.
And it will work just fine, only the display.
You need to use the orignal homebutton and sensor/frontcam cable.
The screws in the bottom wont fit unfortuanately
1 Comment:
It can work but will have issues
by Share
Add a comment
Add your answer
Alex Pro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 5,466
