The Canon EOS Rebel T2i is a continuation of Canon's entry-level line of DSLR cameras, the Rebel series. The Rebel T2i is also known as the 550D and the Kiss X4.
Why has my dial started acting strangly?
The dial on my Canon 550D has started acting strangely. When I turn the dial to manual mode it just stays in P mode, and won't work in video mode. Other times when I turn it to Portrait, Landscape or any of the other modes a different mode appears on the display, sometimes though it will come up with the mode you have selected. I thought it might be software but the same happens when no SD card is in the camera. Any thoughts? Could it be the dial packing up?
Add a comment
1 Answer
Patrick Ramsey going only by your description of the problem it appears as if you are having a failing mode dial. Use these guides to get into your camera and check the ribbon cables to ensure thy are properly seated. Ultimately it sounds like your dial switch requires replacement.
Add a comment
Add your answer
Patrick Ramsey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 327
