Up to 20% off select tools
A 95.2mm by 56.5mm by 18.3mm point-and-shoot digital camera released in March 2012.
file error message pop up
Why does a file error message pop up when looking through pictures I have taken instead of a picture that I took, but is no longer on camera? instead it says file error with a triangle.
Add a comment
1 Answer
Chosen Solution
@froggman from the manual:
The following issue can cause a File Error message:
  • The picture file is corrupted
  • The picture was taken with a different manufacturer's camerahe memory card inside your camera is not formatted
  • The memory card in the camera is not compatible or defective and needs to be repalced.
I'd start with formatting the card and see if that works. If not replace it with a new one. you can get the user manual from here which tells you how to format the card etc.
Score 2
Add a comment
Add your answer
Justin Hoelscher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,194
