Up to 20% off select tools
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
My phone has a bootloop problem
My phone has a bootloop problem and i tried to repair myself. The repiar was successfull but after two of working, the issue started again.. so i repaired it agian and aftr the cleaning the dust inside my phone, i small chip was hanging to the motherboard.. Well, I know i f**d up, now i want the original LG Motherboard for LG V10 at&t.. Where can i buy the replacement?
Thanks in advance!
Score 2
3 Comments
i checked that before,but i need the original motherboard..not the replicas
by Share
Fixed wife's V10 after it constantly rebooted. I work for CameraSecurityReviews.com in Indiana as a repair technician servicing audio and video equipment like this http://camerasecurityreviews.com/4-chann... . The root cause of this reboot issue, and sometimes overheat issue found in G4,G5 and V10...is a ball-array mounted IC on the main PCB on the screen side of the board. Its a larger IC without the interference shield over it.
The fix involves heating the IC and PCB with hot air and allowing the solder underneath the re-flow and make a connection again. Don't melt any plastic connectors. Also take out any SD card and the SIM card so they won't melt! Hope this helps someone.
by Share
I baked my motherboard. Worked like a charm. Using it for more than a daynow with no issues.
by Share
Add a comment
1 Answer
Chosen Solution
Hi!
You could try hereor here.
Score 5
3 Comments:
@oscarsp @yvaneck jkingsnorth sorry but no SPAM here. Just a couple of benign links to a replacement board.
by Share
Thanks for the warning @oldturkey03 , but I vote as not spam. The links help to solve the problem and I know that @alexniculescu is a good assistant does not send spam. I apologize if I made a mistake marking it.
by Share
@oscarsp it's all good. Not a warning just making sure helpful answers are not being misunderstood :-) No apologies necessary
by Share
Add a comment
Add your answer
Anche Karthikesh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 12,631
