Mode dial not functioning
The mode dial (pos 10 in pict.manual) appears not to function, after selecting a position, the camera remains in automatic mode, dial moves in a sticky way.
any solution?
Thanks
Paul
any solution?
Thanks
Paul
By using contact cleaner spray to the dials and buttons, after which I applied compressed air in order to dry the areas, problem was solved. Had to do it a couple of times
Makes a lot of sense what you tried, although I would have used rubbing alcohol and no compressed air. Good job, you figured it out yourself.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 1,399
