Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
Speedometer works when it wants
speedometer works when it wants RPM gauge works just fine. could the wires on the sensor be loose? Where is the sensor located? 1995 Honda Accord 5 speed thank you
Score 2
Add a comment
Chosen Solution
Best bet is to replace the speed sensor . You need to remove the air cleaner and look down on the back side of the motor where the motor meets the gearbox . Under the distributer and the water hoses on the gearbox
http://breebamboo.ipage.com/archive/imag...
Hope this helps
Score 4
1 Comment:
Is this in the same location for a 95 Accord LX, Automatic 2.2L?
by
Add a comment
There's a good chance your speed sensor is going bad, specifically the speed control sensor. I had the same issue in mine. So...what Jimfixer up there said
Add a comment
Add your answer
Barbara Edgman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,690
