Touch screen not respond
The touch screen works only in the recovery mode
I have done hard reset and still the problem !!?????
If I'm not mistaken you navigate with the volume buttons and the power button in recovery mode so you don't use the touch screen . So the digitizer is not working so as you did not specify which oppo phone you have I canot direct you to a digitizer but you can find them on ebay or amazon . Oppo Phone
This guide page will show screen replacement for 3 different oppo phones . Hope this helps
I have oppo a37
My problem is there is no responding from touch screen at all ,so I tried to fix the problem with hard reset but it not help
When I was trying to do the hard reset i see touch screen Respond well but only in the recovery mode ,after reboot the phone to normal mode still the problem no responding from touch screen .
hi I am currently using f1s screen can’t be touch no response what will I do?
jimfixerir i just replace the lcd with frame the led lights lighten up the back buttons lighten but the screen doesnt work, it is still black but it rings there is a soundwhat might be the problem? for oppo f1s
ओप्पो a3s का टच नहीं काम कर रहा है
I am using oppo reno 6z 5g. The touchscreen was unresponsive. I tried hard reset but another problem arises. It opted me to enter my password. I cannot enter my password for the screen is still unresponsive. What will I do?
Same issue here i cannot touch in recovery mode .
i have same problem, new screen, working on boot to enter pin, but not working in recovery so i can't reset it. oddly to reset oppo recovery ask me a 4 digit pin that is displayed but i can't enter it because i can't touch numbers...
is it a display hw problem or a sw limitation of the oppo phone? mine is a54s
My phone is broken and screen is out 3,4 inside a paper
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 130
All Time: 52,853
6 Comments
My phone touch screen is working but display is not working what the problem with my phone
by Vanja Narender Share
मेरे फोन का टच नहीं काम कर रहा है
by NS Divy katyayani Share
My screen isn’t working at all but all bottons on the side are all workin
by Ephoria Share
Oppo r831k touch not working
by handsomeprince45 Share
I'm using Oppo Reno 2z screen not responding
by Lambrusco Namaduk Share
Show 1 more comment
