Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
PowerBook G4 Titanium 800 MHz Lock-up
My PB G4 Ti 800 MHz will start OK, but after ten minutes of being using any application, it locks-up and I have to do a reset to get control o f the computer. Also I can only the lower slot for memory. If I install memory in the upper slot only, I get the tone as if no memory is in stalled.
If I do not run any application the will not lock at all, but as soon as start an supplication the PB locks-u again :-(
Update
My HD is not dying it works just fine. The problem I believe is with something on the motherboard. The computer will boot but I can only use it for about 10 minutes. Then it locks-up. If I shut it down by pushing the power button until it powers off and restart the computer it comes on again for another 10 minutes.
As for cleaning the upper memory slot, I have already this as well as clean the edge of the memory module.
Thought there was a recall a very long time ago PB G4 Ti computers that had problem with their memory slots.
Does anyone remember this type of problem?
Walter
Score 1
Add a comment
Chosen Solution
Here is a link to Apples test procedures. In particular I would like you to run disk repair. For the memory problem only being able to use one stick is a common problem but you can try cleaning to socket with alcohol. Make sure the unit is unplugged and the battery removed first.
I hope these measures help you.
http://support.apple.com/kb/ts1417
Score 2
Add a comment
Sounds like your hdd is dying.. Time for a new one
Add a comment
Add your answer
walter will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 1,513
