Dell Streak was released on August 13, 2010 and is exclusively available on AT&T's cellular network in the US.
Dell Streak upper bezel loose?
The upper bezel on my dell streak is slightly raised. I assume their is some dirt under it. From reading the break down i think i can fix it but had some questions.
  1. Do i have to have the plastic tool to remove the upper bezel.
  2. Is the upper bezel glued on in any way if so will it need to be re-glued.
  3. Is their any possible breakage to look out for when prying it up.
Thank you for your time.
Score -1
Add a comment
1 Answer
Chosen Solution
Do you mean the piece removed in this step? If so, it is attached to the Streak with what resembles viscous double-stick tape. We reassembled ours after the teardown and it held together fine - just try not to touch the adhesive or get it dirty while it is apart. The plastic opening tools we use are nice to take stuff like this apart because they're soft enough to not damage the parts while you pry them apart. That being said, any thin pry tool can be used as long as you are careful. It looks like you'll want to pry up near the spot we pried in the picture and then lift the bezel from the edge nearest the glass front panel as there may be little retaining clips along its top edge (I can't really remember).
Score 2
Add a comment
Add your answer
Shane Gulley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,610
