The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
Tablet stuck in no command mode,will not reboot
Tablet says failed to mount external SD no such device. I have tried recovery system update,wipe cache partition,wipe data/factory reset,apply update from cache,update rkimage,update from external storage and apply update CV from adb, nothing works,screen is stuck on no command. All I did was turn the tablet on
Score 1
Add a comment
Chosen Solution
Check the USB port that you connect to your computer with. Look for bent pins or something lodged in the port . If there is something in the port use a toothpick or plastic pic to remove don't use anything metal . If this brings no joy , is there a card reader or a sd card in the machine , if so take out any card that may be in the tablet . If there is no card in check the slots for debris and clean them . If you get no joy from this remove the battery . Open the case and disconnect the battery . If the battery is soldered to the board then remove the soldered ground only for a few minutes then resolder . Hope this helps
Score 2
Add a comment
same problem tied everthing
Add a comment
Add your answer
tabletdummy_ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 3,098
