Up to 20% off select tools
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
iPhone 7 Plus Boot Loop
Hi. My iPhone 7 Plus Keeps rebooting. Boot loop. It Turns on to white apple logo and then shuts off and then turns back on. Keeps doing that repeatedly. I've already tried a restore from my computer and it resets and shows the reset bar but then comes back to the reboot screen. Please Help. Thanks in advance.
Score 10
4 Comments
i got this issue its two way one is disconnect the front camera seconed disconnect the home button
by Share
thanks for the advice, worked wonders.
by Share
I'm having the same issue recently restored an iPhone 7 plus and the home home button flex cable must have been damaged i the process is their any way around this.any way to get another functional home button? and advice is much appreciated.
by Share
Look up JC home button. There are 3 or 4 versions. So get the latest one.
by Share
Add a comment
Most Helpful Answer
In my experience the most common cause of a bootloop an an iPhone 7 is the Audio IC chip… or rather the lack thereof. This chip will loose some of its solder joints similar to how the touch IC would on the iPhone 6 plus.
Here are some images showing where it is and how to get to it.
The only real way to fix it is to remove this chip, re-ball, and re-solder it back. This does come with some risk and should only be done by an experienced professional.
Also, with some of the later updates of iOS, most iPhones will boot up showing only a black or white screen before showing an Apple logo. This alone doesn’t indicate any kind of issue with your phone.
Score 2
1 Comment:
i done it ans was very good solution. with thankful
by Share
Add a comment
I have not worked on the 7 plus yet but have had this issue with several of the 6 plus iphones...both of which require board level repair. 1st repair is to replace the Tristar (U2) charging IC Chip and 2nd is to verify proper voltage on NAND (Hard Drive) (Reball has helped).
It could be a software issue as well I imagine but if you are not able to restore, have restored with same issue, or get an error message on Itunes, I think your best bet is to take it to a good repair shop or to Apple if under warranty.
Score 1
1 Comment:
It did turn on and boot to the setup screen once yesterday but the home button wasn't working so I couldn't set it up and turned it off to restart it. It started doing it again.
by Share
Add a comment
on iOS 11 you don't test out screens.... replace everything on the lcd and install the new lcd with every screws, close up the phone. then turn on.
note: there are many diff kinds of screens that doesn't work with iOS 11.
if problem continues, check every wiring on the new lcd.... or try putting everything on old screen or working gem screen...
in some cases i hard reset 3 times and plug in the charger.
Score 1
1 Comment:
Do you know a reliable supplier that has compatible screens?
by Share
Add a comment
Reinstall the screen with the front camera detached and see if that kicks it out of the loop. The cameras are very fragile and often times when the phone gets hot, It damages the camera and causes that to enter boot loop. If this works, simply replacing the front camera will usually fix the issue.
Score 1
Add a comment
Please try to use 3uTools to restore your device. Hope it would work for you.
Add a comment
Hi there try this, Press and hold the Power button and Volume Down button simultaneously until you see the Connect to iTunes screen. Do not release the buttons when you see the Apple logo because you will need to enter recovery mode first. You will then be prompted with the option to Restore or Update. When holding the buttons down it should take around the 20 second mark.
1 Comment:
I tried it but it doesn’t do anything
by Share
Add a comment
Fix iPhone Stuck In Boot Loop On Apple Logo without losing your files https://youtu.be/0XGMFmHLFCw
Add a comment
To fix iPhone boot loop, this post will be of assistance. I have solved the same problem with the method from it.
Add a comment
My iphone 7 plus boot loop struck iphone logo and computer logo iam not having computer with out computer and laptop repair the phone
Add a comment
Add your answer
xsulemanhanifx will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 58
All Time: 24,367
