The Astro A40 TR Plus Mixamp M80, manufactured by Astro gaming, is a headset and amp bundle used to increase the stereo sound quality for the Xbox One .
Is the device compatible with other XBox devices?
Solely, XBox 1 system?
Add a comment
1 Answer
Sort of! There are two devices and one is compatible (to a point) while the other is not.
The headphone portion of the headset will work with anything that has a 3.5mm TRS or TRRS port (headphone jack) but the microphone will only work if the port supports a CTIA TRRS connection. The Xbox 360 controller port does not support the microphone but it does support the headphones.
The Mixamp M80 only works with the Xbox One. Perhaps there is a workaround, but the Mixamp M80 was designed for the Xbox One system.
Sources:
http://forums.astrogaming.com/index.php?...
Add a comment
Add your answer
Loretta Sohappy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 236
