Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
Fan not Running! Ventilation insufficiant
Hey everyone! Ive got a great big ol problem.
I get the "Ventilation is insufficiant" error coming up on an XBOX 360 E.
I have opened the device up, and ran it without the case, where i get the same issue. at this time, the fan is never running. i have tried many things to get the fan to run, which are listed below.
1) I Applied 5.5V directly across the fans /+ aGND/ pins. The fan ran, which told me, that the pins on the board are not supplying sufficiant Voltage to the device.
2) With the knoledge gained from above, I Decided to try a 12V Mod, and i spliced the /+ to GND/ of the fan to the /12V to GND/ of the Disc Tray, which still provided no power to the fan.
I am unable to figure out why the device will not Fan On. does anyone else have some information i can use to fix this issue? the device knows it is overheating, but wont power the fan.
Score 1
1 Comment
I've got the same issue bu I've rugged a 9v battery it the fan vcc pin1 and and (red and black wires). And it keeps the console humming another day
by
Add a comment
Chosen Solution
have you mesured the fan headers with a multimeter?
if anything else, run an independent power supply (or jump the xbox power supply), and make it run full throttle all the time.
Score 2
Add a comment
I've just jumped it to a 9v battery
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 62
All Time: 4,648
