The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
Xbox One Controller only works when plugged in
My Xbox One Controller will only work if it's plugged into a power source. It doesn't matter how many times I change the batteries it won't turn on it unless it is plugged into the Xbox. Wanted to know if there was a fix for it or if it is something that I am just going to have to deal with.
Score 3
5 Comments
I had this same issue then I just reset my Xbox and fixed the problem. Who would have thought.
by
The only thing that worked for me was turning on a broken controller then the new controller turned on and stayed on.
It would only work plugged in.
by
Had the same problem with two of my controller. At the same time. Was casting a youtube video to the box screen, Reset the Xbox. The problem went away!
by
None of these solutions are okay. I didn't just recently purchase an xbox1 to take the controller apart and fix/replace the circuit board..
by
Does anyone know where i can make both my afterglow xbox series x controller work alongside my wireless xbox one controller as a second player on my windows 10 pc? In programs where I have to manually map buttons like say the Dolphin emulator only one controller responds while the other is either locked out or unrecognized. Honestly, whatever happened to just plugging crap in? I never knew controllers required profiles.
by
Add a comment
1 Answer
Chosen Solution
If you continue having issues turning on your Xbox One Wireless Controller, check out this Xbox One Wireless Controller Won't Turn On Problem Page.
Disassemble it and reassemble it to better secure connections using this guide:
Xbox One Wireless Controller Top Motherboard Replacement
If that doesn't fix it, than replacing the top motherboard should.
Make sure your batteries are both putting out at least 1.5v.
Hope this helps!
Score 5
1 Comment:
Mine is still not working and it is not one where i have to plug in in order for it to work it is one that i can sit on my bed with it and play when it is charged and i get frustrated when it just stops working can someone please help me my mom is going to be mad if she finds out my controller is doing this.-Thank you-
by
Add a comment
Add your answer
Adam Lieberman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 33
Past 30 Days: 171
All Time: 79,510
