Up to 20% off select tools
Released in 2010, the Sony Vaio SVE11B11L: also known as part of the Sony Vaio E Series. Produced by the Sony Company and is associated with other models, such as: SVE11125CXB, SVE11125CXW, SVE11135CXB, and SVE11135CXW.
Not didating the hard drive
i removed the cmos battery from the mother board after fixing it back, when i tried to on it, i discovered that the system is no longer dictating the hard drive, so in this case, what do i do?
2 Comments
tanx so much, but i have done that sir, but the issue here is that, the system is not entering BIOS setup, i have been using my F2 command but it has refused to enter setup, is still showing operating system not found, so what do i do next
by Share
Remove the computer battery and the CMOS battery for 30 minutes, then replace both and try again to enter Setup.
by Share
Add a comment
1 Answer
Most Helpful Answer
Boot to the BIOS, by Tapping the F2 key when you Power On. When the BIOS screen come up, scroll to the "Disk #1" setting and press Enter. It should find your hard drive. Save and Exit, and your drive should now be the default.
Good luck,
Russ
Score 1
Add a comment
Add your answer
onyebuchiadieze will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 32
All Time: 418
