Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
JBL not turning on
My JBL Xtreme just randomly stopped working even though it wasn't damaged and it's fairly new (almost 2 months). The whole problem is that when i press the turn on button, it shows up a blue light instead of white and then flashes away. As long as i hold the power button, the blue light stays on. I can charge my phone with the speaker but i can't charge itself as the white battery lights don't show up. Please help!
Score 3
1 Comment
I’m not worried about the point. I wanna know how to turn it on. It’s not turning on at all. Thank you so it wasn’t really helpful.
by
Add a comment
Most Helpful Answer
Putt it in the charger until some lights are turning on if this doesn't happen, then push the power button when it is in the charger. If the power button turns white contact me again.
Score 3
4 Comments:
I had same problem plz help me
by
My JNL Extreem 2 was purchased in March, it all of a sudden will not turn on. And will not charge
by
It is not turns white, remains blue. Without the charger it is blue until I press it, with the charger it is always just blue, and does not react at all.
by
What can I do about the jbl extreme 3 that is showing light on power button but not showing sign to on
by
Add a comment
I found out the hard way that some people like to give tips on how to reset, or get less base on JBL extreme speaker. Tips like press some buttons at the same time like the power button, the play button and some other button all together. I did follow these tips once and my speaker died. So my tip is never to follow these tips but try and get in contact with JBL service because they have a great service policy.
1 Comment:
I agree, I tried, now I get nothing at all... just dead. Slight flicker when I hit power, that’s it. Charger plugged, does nothing at all.. you have any ideas
by
Add a comment
I have the same issue, checked the battery it is above 8V. Turn apart PCB seems healthy no burnt components etc...
Add a comment
Add your answer
threeloco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 27
All Time: 7,426
