Flooded Mac Mini Power Adapter
The area where I keep my mac mini was flooded with the mac mini turned off. The power supply was actually full of water as it was laying on the floor. After drilling a hole in the power adapter to drain out the water, and allowing it to dry out fully, it still will not power on the machine at all. What are the chances that only the power adapter is bad and not the mini also? There is no way to test it since I do not know anyone else with this same power adapter. Thank you.
2 Comments
Did your mini get wet at all? If not you should be OK.
The hard part is finding one of these older power bricks
by DanJ Share
Thank you for your opinion. I have found a power brick on eBay for less than $20.00. It is worth the risk to see if it will work.
by ndwig Share
