Memory stick will not stay down
My Memory stick will not stay down. I push it in to take some pics and it pops right back up
Daniel Austin, Could be a broken piece off card/dust/debri or damaged inside the card slot mis-aligned lock spring/pin. Use a magnifier and aim a flashlight down the slot and see if there is anything obvious causing the issue. Also try another card if all looks good. If it ends up that the camera needs a new SD memory card slot, it is soldered to the mother board and would be best to have it checked out at a good local camera shop and estimate repair. Links below may be of some help, 1st/2nd link are forums that talks of your issue and 3rd link is video showing what he found to be the problem. Last link is a replacement card reader. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.thephotoforum.com/threads/nik...
https://www.flickr.com/groups/867288@N20...
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 33
All Time: 520
2 Comments
Thank you Very Much, I appreciate your help
by Daniel Austin
Daniel Austin, thanks for replying back, good luck with your camera.
by L Pfaff
