1.3" Full Circle Super AMOLED display, 360 x 360 pixels, 278ppi, 46mm diameter, protected by Gorilla Glass SR+ Samsung Exynos 7270, dual-core 1.0GHz 14nm CPU, 768MB RAM, 4GB internal storage 380 mAh (3G) Li-Ion battery 49 x 46 x 12.9mm, 63g (Frontier) /59g (Classic) Stainless steel 316L casing with rotating ring control, IP-68 certified, water-resistant for up to 30 minutes and up to 1 meter deep plus MIL-STD-810G standard compliant Tizen-based wearable platform Heart rate sensor, gyro, accelerometer, barometer, ambient light, GPS/Glonass Wi-Fi b/g/n, Bluetooth 4.2, NFC, MST and 4G in LTE Frontier model Vibration Microphone with S-Voice support and speaker Wireless charging (WPC Inductive) Support for non-Samsung devices as well
Parts source for rear case?
I shattered my rear case glass (back of watch by the heart rate sensor). I can't find a replacement though. Does anyone have a source?
Score 1
2 Comments:
I have the same problem. It is a hairline crack and its affecting my heart rate sensor. I orderd the new back housing and an 00 tri tool. Have no idea how it got cracked.
by
Anyone know for the front glass?
by
Add a comment
1 Answer
Hi, I had the same issue. And found this:
http://www.ebay.com/itm/Genuine-Samsung-...
2 Comments:
We’re you able to successfully repair this issue with buying a rear bumper replacement as suggested ?
by
Yes. All I did was got the relpacement part and took 4 screws out and replaced. Pretty easy. :)
by
Add a comment
Add your answer
Jim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 6,560
