Up to 20% off select tools
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Error 6 fix?
I've been trying to reinstall iOS 4.2.1 on my old 3G iPhone, but it throws back error 9 or 6 every time. I've already tried most of the common solutions. Can anybody offer any assistance? Thanks!
Update (06/17/2017)
I also forgot, it's stuck in DFU mode, and the iOS was corrupted when I got it.
Score 1
Add a comment
Most Helpful Answer
Try to flash with 3Utools
Score 3
3 Comments:
are you sure all the connections are fine? dock and cable I mean.
by Share
Yes, and I was doing it wrong anyway. :) I downloaded the actual program, and it fails at 13% saying invalid serial number.
by Share
This tool is very useful~ And about invaild serial number, you can try to enter your device to DFU mode and flash again.
by Share
Add a comment
Your device is stuck on DFU, you can exit that with 3uTools.
Score 1
2 Comments:
With the serial number issue, it refuses to flash. It's also stuck in a somewhat damaged DFU mode, so the only way I can get it to even begin the process is by cheating with iTunes and unplugging it once it reenters recovery mode. I'm honestly a little stumped on this.
by Share
If serial number issue issue still exists, there may be hardware issue. You are suggested to get a repairman to check your device.
by Share
Add a comment
Add your answer
Nikola Wozniak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 32
All Time: 680
