The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Got wet now power button not working
My Note 5 got water in it, dried it out and everything started working again except the power button. If it cant be fixed, can I send it to Samsung for repairs ?
Add a comment
Chosen Solution
Bill White, Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem perhaps with power button. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. If not wanting to do the repair yourself, you can contact Samsung for a preferred service center or pop into a good local cell phone repair shop and have them diagnose and estimate repair. Good luck.
Samsung Galaxy Note5 Teardown
Electronics Water Damage
http://www.samsung.com/ca/support/
Score 2
Add a comment
If your phone gets wet from rain etc and its exhibiting problems then quickly do what I did, switch off your phone if you can and grab a blow drier and put it on a cool setting (not hot) then place the blow drier on the bottom of the note 5 where the holes are and also take out the pen to increase air flow. My power button and most other button werent working so i done this and it works perfect now. Gotta be quick though to prevent further damage.
Score 2
2 Comments:
The same thing happened to me but its already been 1 day
by
my power button isnt working just now and i am tending to that right away, thanks
by
Add a comment
Very good information
สล็อต
[|สล็อตออนไลน์]
[|สล็อตออนไลน์888]
[|เกมส์สล็อต]
Add a comment
Add your answer
Bill White will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 16
All Time: 23,975
